After reading several horror stories about seized swing arm bolts, I finally got around to checking mind. Against all odds it still turns relatively easily. I would like to keep it that way but I have never removed a swing arm bolt on this bike. Is it possible to remove the bolt, clean, grease and refit without removing the engine/swing arm (if I support everything)? Or is there anything to be gained in totally stripping it down? (sounds like a job for the winter)
