Optimate problems..
MAC
Have read other problems re this. Went to fire her up after about 3 weeks, (well the sun is shining!) having been 'connected' - 2 green lights etc but just wouldn't start, sluggish to non-existent turn over.
Other problem - mirrors tend to blow back in on themselves at speed(ish) and appear non-tightenable.
All tints/hips greatly appreciated!!
Mac::
No idea Mac but a few whacks with the half pounder should encourage itself to behave!!! :thumbs: :thumbs: :thumbs:
Hi Mac,
From the amount of posts about them I reckon these Optimates are more bother than they are worth. I've never used one, just take the battery off the bike, keep it in the warm and give it a trickle charge at a very low current about once a month. I can usually get 5 or 6 years out of a battery so I must be doing something right.
Your SS must be one of the carbed ones, the mirrors on them can be a right bugger to keep tight. If you take them off the bike you will see a cross head self-tapper that holds the swivel together. You can try roughening up the plastic parts and tightening the screw good and tight - some folks put the mirror in the freezer for while first. My own solution was to run an M5 tap down the hole and replace the self-tapper with an M5 cap screw. This enabled me to achieve a degree of tightness that kept the mirror in place but still allowed it to be adjusted - just.
Cheers for that Derek - it's the first time the optimate's given me any hassle in about 12 months but I'll try your suggestion for the mirrors, although my freezer's not big enough to get the Duke in!!
Tar Mac.
Derek said:
Hi Mac,
Hi Mac & Derek,
This really surprised me. We've sold loads (literally hundreds) of these and i've never heard of a problem ever!:eek:
They are usually absolutely faultless! Mac, try and put it back on charge, make sure all the connectors are on nice and tight, leave it for 24 / 48 hours and try again. If it's still the same, send me a PM or give me a call and i'll see if I can help further.
As to Dereks advice on mirrors, couldn't have put it better myself, nice one!:)
Mart
Usually the main cause of an optimate failing, is dodgy connections.
Make sure they are thoroughly clean & connections are 'very' intact before fitting to bike. Often the first failures are noticed when you try & run the bike up after its first long lay off. The optimate has usually be stuffed in the corner of the garage for the summer, attracting dirt/dust & the like.
AK, who sells lots too:)
Optimate problems ...
Thanks all, I now have two green lights but in the interests of neighbourlieness I'll leave it 'til the morning before I start her up - carbon cans etc. - oh, b*****ks I'm off to York on 23rd Feb so I'm going to start her up anyway - who cares?
Cheers Mac.
Martin, Just read your comments. Had the bike for two years now - don't know the age of the battery. Could it be that it's just about goosed?
Thanks, Mac.
Usual life of a battery on any bike is about 2 - 3 years.
However, I know many do go on for a lot longer (even if they arent looked after!:eek: ) the one on one of our race bikes is well over 4 years old!!
The one on my tricolour gave up after 2 & a half year tho - and it WAS looked after.
Swings & roundabouts
Alan
Battery could be sulphonated. Optimate measures the charge (voltage) etc so battery could still look OK to optimates electronics, but when you do the business with the starter, if the battery is sulphonated the discharge current wont be high enough to turn the starter cause the voltage drops way off under load. Only way to check is to get the battery tested ( should be free or cheap) only takes a second or two with the right tester, worth gettin it checked
