Pantah 900 project
budgie955
Member
Hi all
I'm on with a real challenge, a 600 pantah chassis with a 900ss IE engine slotted in. I have keihin flat side repica carbs fitted at the mo , and ignitek ignition. The standard swinging arm has been adapted to fit the 900 engine but the rear exhaust is a challenge, i will probably have to route it under the seat.
Anyone in sheffield barnsley area who can fabricate an exhaust? I have a 900 ss system that can be hacked up , so close to firing it up !
Regards
Welcome Budgie955, guessing you might have, or had a Daytona too ?
Always good to read about people's projects !! (y)
OJZ Engineering are not that far from you, but not the cheapest place to go, but his welding is a thing to behold !
