Here's another interesting experiment that I did recently with the DB2. It's a thing that I really didn't need to do, but was interested in what the outcome might be. It's a bit of a technical/mathematical one, but hopefully someone finds this as interesting as I do.
When setting up the DB2SR ECU, I set the timing of of the fuel injection so that the injectors finished squirting into the throttle bodies 400 degrees after TDC. My logic was that this was a point about a third of the way into to intake cycle - the valve would open midway through the injection event, and the inrush of air would pull the atomised fuel in nice and efficiently.
I figured this from Brad Black's
excellent discussion on cam profiles...
I'm running ST2 cams on the Bim, so, when measured on a full 720 degree engine cycle (that is, two full revolutions of the crank), using the above data, we can calculate that the intake valve will open at 331 degrees and close at 613 degrees, and the chosen 400 degrees was a point midway between the valve opening and the centreline of the intake phase.
Now, I was recently watching the excellent YouTube channel
Superbike Surgery, and Jim has been doing a bit of work on a Bimota SB8R, which caught my interest. Jim was lamenting over the spray pattern of the injectors that the SB8R uses (which are side-fed versions of the same Marelli injectors that the DB2SR, and many other Ducs use).
Later in the video - he was looking at a timing diagram of the Suzuki TL1000R engine - glancing at the diagram onscreen - it dawned on me that the Suzuki was firing the injectors on closed valves, and deliberately so. This started my brain churning a bit.
Last night, I stumbled across this super-interesting article -
(click here) - highly worth a read. In summary, atomisation is important for cold starts, but once up to temperature, it is not a significant factor (the valve-open time will decrease as the crank speed increases, meaning that you can never have all of your injection into an open valve, and the ratio of spray to closed valve/spray to open valve will reduce as the engine speeds up - instead - the significant factor is the
vapourisation of the fuel as it hits the hot valve. Interesting).
So, of course, that left me wondering: the 400 degrees ATDC setting that I used on the DB2SR was a guess based on what I understood at the time. Knowing what I do now - what should I do? Well - I decided to run a test.
I warmed up the DB2SR in the garage at idle, hooked up my laptop to the ECU, then ran some automation software that would set the (end of the) injection event to 200 degrees ATDC (which is well before the intake opens), and increase it by three degrees every five seconds until it got to 650 degrees ATDC (well after the intake closes), whilst carrying out full logging of what was going on. The results are interesting - here's a chart that I plotted using the ECU software.
Because I have an wideband O2 sensor in the exhaust, I was able to plot a scatter chart of Fuel Angle against RPM and Air Fuel Ratio (AFR). Engine tuning often looks to these values - after all, an engine running efficiently will run with higher RPM for a given amount of fuel, and of course the AFR figure will give an indication of the completeness of the burn. In the chart above, you can see a clear curve where the mean RPM appears to be highest around about -460 BTDC. I loaded the dataset into a statistics software package (R) and did some magic to fit a curve to the data so you can more precisely see the shape.
Slightly annoyingly - the metric that the software recorded appears to be the
start of the injection event (which I think explains the slightly diagonal nature of some of those vertical stripes that you can see - if the fuel pulse width changes - for example, because the RPM went up), also it records it as the angle BTDC. That makes it quite difficult to understand what the *end of injection* angle should be and how it relates to the configured settings (end of injection between 200 and 650 ATDC). However - with a little bit of thought and maths, we can refactor the data to compensate for this- in this next one, the chart relates to the 200-650 degree range that I tested, and I've also marked up the points of intake open and close for clarity.
The point of max RPM appears to be about 515 degrees ATDC, which is interestingly much later than my original choice of 400 degrees, and before the valve fully closes, and does seem to suggest that the original hypothesis (firing on a closed valve is a good thing) may be incorrect.
However - while I'm surprised that this "sweet spot" appears so late, I then realise that there is another variable at play. Here's that same scatter plot again, this time, with the colours showing engine temperature, rather than AFR. Are we measuring a sweet spot due to the injector timing, or just that the engine is hotter, and vaporising the fuel better?
Hmmm - more thought and development required, I think. Perhaps I'll try the test again, but tuning the injector timing in reverse order from 650 to 200, or in a randomised order, and see if I get similar results. Not tonight though, best that I give the neighbours a break from the noise.
Interested in your thoughts!
Mike
