bang on with the site on the bearings,the only thing with it is that the site says bearing width is 15mm mine are 17mm,other than that bang on,the other thing am on the hunt for is clutch friction plates,do you know of any cheap suppliers,mine has the usual tamborine rattle when clutch is pulled home,and a rumble when released,the basket is all grooved,this will be one of the next things on the wish list.your offer of doing the belts is one i want to do as soon as poss bikes over 24000 and belts are more than likely going to go soon,can you supply belts or do i need to get them?
