I'm thinking of buying a pro cordless chainsaw for work. I will be using it on and off all day every day so I need to be able to charge it from the car as I'm never anywhere near a power source. So I need an inverter. They vary from £40 to £500 and I don't know what I need.
It will only be used for charging the saw battery so I only need a single 230v socket and nothing with a heavy power drain will be run off it, as in appliances in camper vans etc.
I've no idea what spec I need. Don't want to waste money but I need to know it will run the charger reliably. The batteries, if it's relevant, are 40v 9 AH with a fast charger (30-40 minutes). Ideally I'd like crocodile clips so I can charge directly off the battery - otherwise the engine needs to be left running - and preferably a 12v socket lead as well so I can charge while I'm driving.
Any recommendations?
