There were a few posts on the DOCGB FB group over the past 2-3 days about lithium batteries and fitting them on older bikes. Things along the lines of :
“If you want better starting fit a lithium battery”
“big weight saving if you fit a lithium battery”
“no need to use a special charger, I just use my old xxxx one”.
“no need to worry about them overheating today, they have built in protection”
“I saved £40 by buying a XYZ one rather than one of them shido ones”
etc etc etc.
As soon as anyone chipped in with ;
“you need the change the rec/rec as well” or,
“you can’t charge it with an Optimate 3” or,
“you’re better off spending more on a reputable brand”
etc etc
they got flamed. The usual response being,
“I’ve not had a problem in the x years I’ve had mine on my …”
Now I know there’s a few in here have fitted them, I know newer bikes now come with them, I know there’s a few on here that know a fair bit about electronics and batteries etc., I also know lithium battery technology and packaging has moved on in the past few years. Thus, as I’d like to understand more about this subject and as it will probably be of interest to numerous others, I thought I’d ask the Hive to contribute to a thread to put this thorny subject to bed once and for all.
ps. I did a search before posting and found these 4 threads.
pps it would be nice if we could keep this on topic.
ppps it would be nice if I won the lottery and I guess there’s more chance of that than keeping this on topic or helpful
etc etc etc.
etc etc
Mosfet Regulator Conversion - Lithium Battery Safe
I've decided to reproduce an article I originally posted on The Ducati Forum as it's a one that keeps getting referenced by others a bit when looking into installing a Lithium battery into an older Ducati that wasn't intended to be equiped with one originally, as it usually preceeded the...
www.ducati.community
Shorai Lithium Battery - Given Up The Ghost.
My super expensive Shorai LFX18A-BS12 battery on the 1098R seems to have given up the ghost. 👻 The battery tender has been showing an error for about a month and I got round to turning it off and back on today only for the charger to not detect the battery. Fetch the key and turn the ignition on...
Warning Over Heat Issue - 2009 Ducati 1098r Lithium Battery Failure
Just removed a dead Lithium battery from a 1098R and sent it back to its owner (so I can no longer do any further tests). Looks like it got pretty hot.... enough to melt the case of the Lipo battery. Apologies for the poor picture, as you can see the middle of the case is swollen. Stu when...
