Well not really much of a project. It started a few weeks before the Masher when I got a pair of ST2 heads off eBay for a song.
The heads have been ported but were bare with no valves, cams, rockers etc.
The plan was to fit them to the 907ie, swapping over the camshafts, etc. (pity they didn't come with the much sought after ST2 cams
) and thanks to Brian & Duncan for contributing the valves. But if you compare the 2 heads in the picture below you'll see that something is missing...
The drilling for the camshaft drive
Like the 900SS, the 907 has a mechanical revcounter, whereas the ST has an electronic revcounter and although the boss is cast in the head it hasn't been drilled. Hopefully with some help from Pict and a local engineer this will be remedied in the next week or two.
To make this more worthwhile I also managed to acquire a pair of ST2 barrels and pistons in very good nick.
So this winter's project is to swap over the barrels and heads effectively converting the 907's engine into an ST2. The extra 40cc should give the bike a bit more grunt and is the sort of mod I don't mind doing because it will look no different externally and can be easily converted back again.
I will post some more as work progresses.
