999 Help
chrisw
Was out on the bike tonight when the battery meter began to flash and display 15.1 volts.
Had a look in the hand book but could find no reference to the meaning of the flashing. I assume it indicates something is amiss and overcharging?
Anyone know for definite? Am I looking at a new regulator?
is your ECU light on?
You need to run the voltage on the battery it should be between 3 and 5k revs and it should be no higher than 15. Also try holding down the left hand button when you switch the ignition on to see if you get any error codes.
Managed to get a meter on the bike.
Everything switched off - 13.04V
Ignition on - 12.83V
Bike started and under load - 14.36V
Reading on LCD - 15.0, 15.1, 15.2 etc to 15.8. Reading then changes to HI or H1 and the EOBD light comes on.
HELP!
Does the voltage change significantly with Revs? If so there is a good chance the charge regulator is goosed. Careful the high voltage could end the life of the bulbs quickly and damage other voltage sensitive components . Ducati know this hence the warning lamps.
Make sure the battery terminals are nice and tight. It seems they must be if the bike is cranking over and starting ok , but the vibration may be making a loose connection worse and therfore giving the regulator nothing to charge ( will show high voltage and erratic as described).
Cant think of anything else for now . Where are you located?
There is no significant change when the engine is reved. The LCD display shows increasing voltage above 15v until it switches to HI and the EOBD light comes on. I have contacted John Cellier (Ducati John) to see if he can help as he services my bike.
Ducati John has been in touch with me and suggested that this could be an ECU fault. !!!!!!£££££££
Have done a bit of trawling and remembered an old post on the DSC re ECU's. In particular this company
http://www.injectioncorrection.co.uk/
They list Ducati ECU's as part of their service.
Have fired an email off to them to see if they can assist. Have also managed to remove the ECU from the bike.
So, watch this space.
Gizmo said:
Does anyone know where Derek is??
I don't really know that much about the 999/749 bikes but it's a possibility that here is a poor connection between the regulator and the battery. If possible try measuring the voltage at the regulator. It should be the same as at the battery. Or try measuring volts between the battery +ve terminal and the output wire of the regulator. You should get 0V, anything more than that means resistance somewhere in between.
I've got exactly the same on mine, took it in to JHP who reset the ECU after checking all the voltages were correct after 30 seconds the fault re-appeared they said the same and being an ECU fault, luckily I've got the original ECU but never got round to swapping it to confirm what they think, it works :thumbs:
ECU goes to Injection Correction tomorrow by courier. Initially for testing and then, hopefully, for repair.
Be really interested if this works, did they quote you a price etc?
Got an update from Injection Correction today. The ECU is faulty and they can repair it - £187.50 + vat. They did ask - what is all the blue liquid inside it? Me thinks - Ah, that would be when the fan chomped through the coolant hose back in April.
Should have it back on Friday :)
Well now you know why it stopped working ;)
Liquids inside electronic bits are never a good thing. They either leave a conductive residue that stops the electronics working correctly or else slowly corrode the circuit board until it fails. If you are aware that this has happened best to flush it out with clean water as soon as possible, shake as much out as possible and dry it with a hair drier. Too late after the event though. Never mind at least you can get it fixed at reasonable(?) cost.
Problem is you can't get to the ECU without taking the battery box and associated gubbins off first. I'm not the only one to have suffered the curse of the badly positioned coolant hose. So, beware!
Update
Got an update from the company re my ECU. News is not good. The damgae caused by the coolant is causing problems with the reprogramming they are trying to do. Have to get back to them on Friday.
How many 749/999 owners have suffered the coolant hose being chomped by the cooling fan on the radiator?
How many 749/999 owners have had the same fault on their ECU?
The ECU has returned from Injection Correction and unfortunately it can't be repaired. The test report shows three fails:
Coil Saturation
Battery Voltage Correction
Self Diagnostics
Then there is the added complication of it being full of blue antifreeze.
So, what to do now. I have spoken to DUK and got a sympathetic ear and have been advised to speak with my local dealer.
Here's what I am looking at if all else fails
OEM ECU from Ducati £791.25
Ultimap U59 ECU from Sigma Performance £528.75
MM Motorsports 5.9/R Nemesis ECU £599 (Available in Jan 2007)
Ref the Nemesis, I phoned them up to ask. £599 to be released in Jan 2007.
Now some good news. I reinstalled the ECU in the bike today. Guess what? Voltage normal, no EOBD light and bike running OK. Can it last?
Can only put it down to the coolant causing the problem.
Many years ago a mechanic mate of mine told me about a mythical shelf all garages have. If you place a faulty component from one car on this shelf for a period of time, when you fit it to another car it will have mysteriously repaired itself. Called the Get Well Shelf. Injection Correction must have such a shelf and my ECU must have been sat on it for the last two weeks!
Will take the bike out today to test.
Good luck, Chris! Let us know how that works out.
The Get Well Shelf sounds similar to the SOSO method of fixing PCs (I find it works in 75% of cases). :D
MYTH-BUSTED :comp2:
AHHHHHHH - 18 miles out and voltage up at 15v and flashing. 35 miles at
15.2v.
Looks like negotiations will have to commence next week.
Dont know whether this will help or not but i believe that all 749/999/998/996R
ecu`s are the same . I have a 999s and i am currently using an ecu from a 749R
I have a power commander looking after the fueling and fitted the 749 ecu to increase the revs.Bought my ecu off ebay brand new for 50 quid. They must be new though somthing to do with the key code.
Keys and clocks are coded to the ECU as soon as the bike ignition is switched on I believe hopefully to put thieves off etc I am guessing but doesn't help the owner if there's an issue like this.
chrisw said:
MYTH-BUSTED :comp2:
15.2v.
it's because you said out loud that it was fixed! keep schtum next time and it'll be fine.
A virgin ECU doesn't become locked to the key set and immobiliser until you use the red key. As long as you use only a black key the ECU remains virgin and can be swapped to another bike.
The bike is finally fixed!
A significant amount has been liberated from my wallet!
Thankfully the amount was not as much as it could have been.
Special thanks have to go to John and Jane at Ducati Leeds for their assistance over several weeks of negotiations.
Also a big thank you to Ducati UK for their sympathetic ear to my problem. Everyone who does not own one may slag off Ducati, but I bet they wished they got the same level of customer service Ducati give their owners!
Hopefully I will get to blow some cobwebs out this weekend before I put her to bed for the winter.
