duncthediver
Dropped 848in garage this evening
Snapped the expensive looking screen mount, now loose, hope ducktape will sort it? not much choice now before the Masher. Bugger:doh:
I found some Bondmaster fast cure epoxy super rapide adhesive 2 prt. Thought not a chance to bond the aluminium, but it sure has rock solid.
The actual part that snapped was the aluminium gold finished front fairing/screen support member. The section snapped just below the RH mirror.
I have some fibreglass material, woven like a sexy negligee. Much better than matting bought from a car shop. I can bring some tomorow, together with epoxy, I have gallons of that stuff you could wrap it with epoxy and job would be sorted in ten minutes. Let me know and I'll bring it to Pete's shop where I believe we are meeting.
Please please please. Sounds like a great idea thanks.
Ducati Leeds have the part in checked this morning, will get bike booked in when i get back. Too shorter notice before the masher to get it fitted before.![]()
If this is a bit you will replace later you could splint it with 2 pack epoxy 'metal' putty squeezed round it with a bit of ally or steel strip in the lump to stop it flexing and 'peeling' off the metal. (You can buy this stuff in plumbers merchants or trade stores - looks like a stick of rock you knead together to activate. Hope this helps
if you think I'm waiting around whilst you do back street bodging on the open road..........or at one of the stops
