The Jester
What's the best way of removing rounded of hex head bolts?
Any input would be appreciated!!
All depends on the location of the bolt? brian.
Best method I've found, (this assumes straight access), is to take a torx or star bit from a socket set, slightly larger, wd on the threads, (but not in the head of the bolt), hammer the bit in firmly til it seats well,
I've had one of these cheap and nasty Draper impact drivers for about 30 years and it has been a godsend many times. Remember to use a hex socket though, preferably one intended for impact use.Good soaking overnight with a unlocking solvent, or WD40 etc, probably just as good.
I was amazed to discover sometime ago that my my cheap and nasty (but still working fine) draper impact driver has a removable tool bit head that allows a socket to be fitted in its place. Select appropriate sized socket and belt away to hearts content. This will either workor you will end up using the other various methods
Try reading 'Zen and the art of Motorcycle Maintenance' first - I've just finished it oddly enough![]()
I've read 'Zen and the Art of Motorcycle Maintenance' twice in the last 40 years or so and each time it was like a different book. Time I read it again.
