Termi fitting questions
clem848
Ive just bought some new Termi's for my Streetfighter 848 and have a few questions with regards to fitting.
Can anyone tell me where the ECU is located on the bike, and what would be the best way to get to it?
Do I need to remove the tank to get to the Air filter?
And can I remove the exhaust flapper valve once the new ECU has been fitted?
Hope someone can answer those for me, as Im completely new to the Ducati!!!!
And I hope Ive put this in the right section of the forum?
Cheers for any help.
Shaun:D
The ECU is usually under the battery, the valve I'm sure can only be removed if you get the front end pipework / manafolds.
Jim
