Gizmo
Forum Geek
Taken from a Ducati Service Bulletin (@ Sport Classic Net) Info as of 27 Jan 2007
lease keep in mind that every time you replace the fuel injector electronic control unit (ECU) or the instrument panel you must properly re-set the throttle position sensor (TPS). DNA also recommends performing this operation to all new Ducati motorcycles during Pre Delivery Inspection. For your reference, listed below are the relative TPS reset values for the following models:
Model-----------Throttle opening (Degrees)--------Linear
M695-----------2.7 +/ - 0.1------------------------YES
S2R 800--------2.7 +/ - 0.1------------------------YES
S2R 1000------3.2 +/ - 0.1-------------------------YES
S4R-------------2.7+/ - 0.1-------------------------YES
S4R S-----------2.7 +/ - 0.1------------------------YES
SS 800----------2.7 +/ - 0.1------------------------YES
ST3-------------3.0 +/ - 0.1-------------------------YES
ST3S-ABS------3.0 +/ - 0.1-------------------------YES
MTS 1100------3.0 +/ - 0.1-------------------------YES
MTS 1100S-----3.0 +/ - 0.1-------------------------YES
HM 1100--------3.0 +/ - 0.1-------------------------YES
HM 1100S-------3.0 +/ - 0.1-------------------------YES
999S TEAM USA
------------------2.3 +/ - 0.1-------------------------YES
1098-1098S-1098 TRI-COLORE
------------------2.6 +/ - 0.1-------------------------YES
GT 1000---------3.2 +/ - 0.1-------------------------YES
SPORT 1000 BIP
------------------3.2 +/ - 0.1-------------------------YES
SPORT 1000S---3.2 +/ - 0.1-------------------------YES
Throttle position sensor description Sport Classic range
Operating description
It provides the ECU with a variable voltage ranging from about 0V up to nearly 5V depending on throttle opening angle;
The electric signal sent by the throttle position sensor is also used to determine how quickly the throttle is being opened or closed. The ECU processes this signal using its engine control strategies to determine ignition advance and injection time depending on engine load, acceleration (pick-up pump function) and deceleration (cut off function);
It is mounted on the throttle body and moves with the throttle shaft.
Electric specifications
Resistance measured across terminals A and B of the throttle position sensor with the connector disconnected should be about 1100 Ohm;
Resistance measured across terminals A and C of the throttle position sensor with the connector disconnected should rise from about 1100 Ohm up to nearly 2000 Ohm when the throttle is turned from the fully closed to the fully open position;
Connect the connector on the throttle position sensor (ensure that the Engine and Body connectors are plugged to the ECU). Turn the key to on and check to ensure that voltage across terminals A and C of the throttle position sensor rises from about 420 mV up to nearly 4.2 V when the throttle is turned from the fully closed to the fully open position;
Connect the connector on the throttle position sensor (ensure that the Engine and Body connectors are connected correctly on the ECU). Turn the key to on and check voltage across terminals A and B of the throttle position sensor connector; reading should be about 4.9 V (view throttle position sensor circuit).
Diagnostic capabilities
The ECU recognizes the following errors:
Short circuit to ground (CCGND)
Open circuit or short circuit to battery voltage (CA CCVBatt)
Setting
The throttle position sensor must be initialized each time the injection system is serviced
Please note that Ducati-UpNorth.com cannot accept any liability for the accuracy or content of this section. Visitors who rely on this information do so at their own risk. If you are unsure it's worth contacting your local Ducati dealer who will be able to help. Do not attempt a repair or modification if you do not have the correct tools or knowledge to do so.
999S TEAM USA
SPORT 1000 BIP
Setting
