WARNING MTS1200 owners: CHECK YOUR FRONT BRAKE HOSES!
Derek
I was checking over the bike this week and I found this :eek:
It's the crossover line from the left to right front calipers that is routed beneath the front mudguard and located in a channel in the black rear section.
I had heard of this happening on others bikes but the last time I checked, last winter, it was fine with no signs of abrasion. Just as well I looked now. Another line is on order and I'll take preventative action to stop this ever happening again.
If you own a 1200 Multistrada have a look at the crossover line on both sides, just where it goes under the edge of the red section of the mudguard.
The mileage is 28,000. The hose has been fretting on the underside of the mudguard.
Thanks Derek can see them now - Factory recall???
Queer. All I did was edit the post re-inserting the original images. :confused:
I've passed the info onto Ducati Glasgow who will also advise Ducati UK. If dealers are alerted to it and a few more show up it could/should be the subject of a recall. From what I can make out from other forums it seems to be more of a problem with the extended rear mudguard, which I think is a standard fitment on UK models.
