You mean this thing of utter beauty ?
It's not the bracket - just the application, it would surely look wonderful holding your toothbrush on your bathroom wall
No, I just took the top of the outer weld and the tank is fully welded on the inside too - pressure may have distorted the flat parts of the tank and as Chad hasn't had a leak in 30+ years of making tanks and looked at me with distain when I said what if it leaks I decided to leave itJoking apart Exi, have you pressure tested/leak checked your tank after rubbing all the welds down. It's not unheard of for leaks to occur in welds after they have been filed/blended. Petrol can take a few days to work it's way through tiny gaps/cracks & it's a real buggar to finf bubbles in your paintwork after you've gone to the expense of painting.![]()
It is looking great and those screw on nipples have been around for a while, the earliest i can recall is 1992 when i built a CB250 low rider.Throttle Cable fitted!
I purchased a universal cable kit off Domino when I bought the quick action throttle. I did think I'd have to drop it down to a mates to get soldered but when I investigated the contents of the kit I found it used screw on nipples
Not seen these before but having fitted them I think they are bloody marvellous. The picture instructions appeared to show that you tighten until the small bolt head shears off but I decided to stop short of that and leave it in place.
Prior to the tank heading off for paint I checked clearances for the cable runs...
The cable route worked well with no restrictions lock to lock - it's almost as though it had been planned from the start
The following pictures show the routing from throttle to carbs:
I might of missed it but are those velocity stacks off the shelf or made to order, don't care what but nothing better to see and hear!!Throttle Cable fitted!
I might of missed it but are those velocity stacks off the shelf or made to order, don't care what but nothing better to see and hear!!![]()
www.ducati.community
Painfully slowly I'd imagine....How will you go about converting the carbs to fuel injection?
All done ages ago! Apart from paint...How's the painfully slow 749 build coming on btw.....![]()
Pull you finger out, you're slower at bolting a few bits together than Eversneer is at riding oneAll done ages ago! Apart from paint...
Love the pipesAnd it's on the floor!
Dry weight without tank and bodywork is 153 KG which I'm well pleased with.
Front to Rear weight biased is 54:46
It's got ... forks.
Are sure you know what you're doing?
Bit potatist.
At least he will know which way round to sit on it.It's got ... forks.
Uh-huhHandle bars do tend to give it away a lil unless your a bit backward, or blind, or both
Wow, you're correct, I should have just copied them and it could have been done in a weekThis is fantastic Exi, by sheer coincidence it looks a bit like those pictures on the wall![]()
