Just been finishing off a few little jobs over the last week - so after 16 months of the build 🥳 it is all finished!!! apart from paint (@chizel excuse for his build that's taking years) 👀
I have a 44 tooth rear sprocket on order to swap out the 46 tooth that's currently fitted.
Oil pressure gauge fitted and some cheap 10:40 oil in for initial start up.
The original engines ran 3700cc but were positioned in the frame at 9 degrees. The KR ran the engine at 18 degrees slant and as I copied the frame exactly mine does too. This meant nothing showing in the site glass with 3700cc in the motor.
I ended up with a smidge over 4000cc in but will have to run to the low oil level to make sure it's not over oiled 👀
The super-dooper fuel line with rigid PTFE inner core I fitted was useless as no matter how hard you clamped it onto the carbs it wouldn't tighten to the point where the fuel line still span easily when twisted by hand. So this has been replaced with a rubber core / cotton braded hose rated for E10 fuels.
A temporary 2 into 1 link has been attached for a slave tank feed.
I also fitted a small filter on the crank case breather - the bike ran with a catch tank before but never had any residue and this is neater.
Fuel overflow pipes were fun, I ordered some Viton tubing that I could only find in China, then realised when it arrived that there were two overflows on each carb. so didn't have enough. But I thought routing 8 separate tubes down and through the belly pan would be a bit naff - so I used Y pieces to connect from each carb to reduce this to 4.
I nipped down to my painters to drill the required 16mm hole in the belly pan prior to paint and ordered the required grommet for the hole.
Tacho cable mounted onto the HT leads...
The ends of my two wiring harness aluminium tubes were annoying me so I drilled, slotted & fitted a couple of tube end bungs which neaten it up nicely.
I've been through the entire bike torqueing everything up to spec. so already for a first fire up which will be scary :eek:
When I'm feeling brave I will take it down to my mate Al's Dyno for a first fire and carb tweaks (if it starts) 👀
Do a video when it's running I'd love to hear it roar 👍👌
