CANNOT CANCEL ERROR, USING CODE
hopefully i have found a few faults after removing the airbox that has solved the problem. the plugs and the airbox were dirty due to an oil breather plate inside the airbox being loose and there was a small leak on the front injector. i think the bike was dropped while being worked on before i owned it and the plate became loose. other small marks on the bike suggest this. the bike is still a pain to start but it is idling ok now. only time will tell when i give it a good run when the salt goes away. plus i will put cleaner in the fuel for the valves. thanks for all the input. one thing i forgot to mention, the connectors from the reg/rec to the stator/generator gets very hot while the bike is running.
